i NEED TO BUILD A BASIC SWICTH BOX THAT LIGHTS A DC BULB WHEN I TURN IT ON.HOWEVER THE BULB SHOULD WORK BETWEEN 24V AND 60VOLTS AS I AM TESTING SOME UNITS THAT VARY WITHIN THIS RANGE.
THANKS GUYS
THANKS GUYS
So you need a way to select the correct voltage for different lamps within that range?i NEED TO BUILD A BASIC SWICTH BOX THAT LIGHTS A DC BULB WHEN I TURN IT ON.HOWEVER THE BULB SHOULD WORK BETWEEN 24V AND 60VOLTS AS I AM TESTING SOME UNITS THAT VARY WITHIN THIS RANGE.
THANKS GUYS
by Don Wilcher
by Duane Benson
by Jake Hertz
