need standard wire gauge with current ratings, link plz
S Thread Starter s2pk Joined Jul 10, 2010 77 Jun 8, 2011 #1 need standard wire gauge with current ratings, link plz
mbohuntr Joined Apr 6, 2009 446 Jun 8, 2011 #2 I googled it in less than 30 seconds... http://www.powerstream.com/Wire_Size.htm
mbohuntr Joined Apr 6, 2009 446 Jun 8, 2011 #5 http://www.reade.com/Conversion/wire_gauge.html Another 30 seconds, you have to be willing to work at it.... Not trying to be smart here, but it was pretty easy.
T tom66 Joined May 9, 2009 2,595 Jun 8, 2011 #6 Wait more than 1 minute per post. You can find the sizes of SWG wires, here. You have the current ratings for AWG wires with sizes, as pointed out by mbohuntr. It is a simple enough look up to compare the two and reason that the current will be limited to the same figure. (oops, too late.)
T tom66 Joined May 9, 2009 2,595 Jun 8, 2011 #8 s2pk said: where are current ratings in this one??? Click to expand... Which one?
Papabravo Joined Feb 24, 2006 21,225 Jun 8, 2011 #9 Just remember 700 circular mills per amp and check out the following: http://frank.harvard.edu/~coldwell/wire-gauge.pdf
S Thread Starter s2pk Joined Jul 10, 2010 77 Jun 8, 2011 #10 http://www.reade.com/Conversion/wire_gauge.html
T tom66 Joined May 9, 2009 2,595 Jun 8, 2011 #11 s2pk said: http://www.reade.com/Conversion/wire_gauge.html Click to expand... That shows wire diameters. This page gives you AWG to current *as well* as wire diameter to current. http://www.powerstream.com/Wire_Size.htm It is a simple enough thing to look up the data in the two tables and combine them to get your result.
SgtWookie Joined Jul 17, 2007 22,230 Jun 8, 2011 #12 Here is a Wikibooks table for SWG vs current capacity: http://en.wikibooks.org/wiki/Practical_Electronics/SWG
