nerdegutta
- Joined Dec 15, 2009
- 2,684
Which diode? D4 in my schema? Or all of them? (post #58)That is my current plan.
Jens has to use too 1N4148 diodes instead of one. Or Make pads and holes for both.
So If I get the diode I can use it, if not I can use two diodes in series..
Plug-and-pray card.I 4got an important point.
The header details is not the same as the pcb ( amp ) See the picture in 1st post. All the connections should be terminated at the bottom header. card is like a umm plug in type
