Suv450
nerdegutta
Joined Dec 15, 2009
2,684
A tip Jensemann. A schematic is often more readable then you split a component like the AN7062. In different parts or slots. Like instead drawing a 74xx04 as one part. You draw it as 6 stand alone inverters. Eagle has no problem handling this.
OK, I understand. I just tired to copy the schema from post #11.
Didn't have the info of the IC in front of me:eek:.
t06afre
Joined May 11, 2009
5,934
By the way R!f@@. Many zener diodes do have a Vf around 1.25 volt. It could be that you can use a zener instead of the MA167 diode
R!f@@
Joined Apr 2, 2009
9,918
That is my current plan.
Jens has to use too 1N4148 diodes instead of one. Or Make pads and holes for both.
So If I get the diode I can use it, if not I can use two diodes in series..
R!f@@
Joined Apr 2, 2009
9,918
I 4got an important point.
The header details is not the same as the pcb ( amp ) See the picture in 1st post. All the connections should be terminated at the bottom header. card is like a umm plug in type
