Surface mount to wire connectors
Discussion in 'General Electronics Chat' started by pebbert9, Feb 9, 2011.
  1. pebbert9
    Sep 17, 2010
    Does anyone have a recommendation on a surface mount to wire connector that they like.
    For through hole I like to use the MTA-100 connectors, about $0.40 ea and no pins to mess with. ( see here: http://www.tycoelectronics.com/catalog/minf/en/692 ) But, no one stocks the surface mount headers for them.
    I have a project I'm working on that cannot use a though hole header. I only need 1 amp and 6-10 pins.
    Thanks,
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Grab a 10 pin MTA right angle header. Place the part of the pins after the bend on PCB pads and solder them. You get lots of contact area.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    They sell surface mount headers that have the pins "gull wing" out at the bottom.
    If much mechanical stress is anticipated, add a bead of 2 part epoxy resin around the bottom edge after soldering.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    take a look at samtec they are an awesome company and will send samples or you can buy direct from them,etc..
