Surface Mount Resistor Value
Discussion in 'The Projects Forum' started by HBN, Mar 29, 2014.
  1. HBN
    Mar 26, 2014
    9
    I am trying to identify a surface mount resistor value for a project.
    Is the picture below a "47D" which would be 301kΩ or "472" which would be 4.7kΩ or something else. Sorry about the lighting. It was hard to get a good shot with proper lighting and magnification.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    That sure is hard to read! How much resistance does it show on an Ohm meter?
    ps, the solder joint on the left seems wrong.
  3. HBN
    Mar 26, 2014
    9
    138k ohm. Can I measure resistance in circuit?
    The marking look like "47d" - small d
    There are some other resistors on the board which are marked "34d" - small 'd" again.
    The small "d" isn't complete though.
    I'll try to post a better picture.
  4. #12
    Nov 30, 2010
    16,705
    7,358
    Fairly often, you can't. For a guaranteed proper reading, you have to unsolder at least one end of the resistor.
    In this case, a surface mount resistor is not going to cooperate. You will have to unsolder both ends.
  5. HBN
    Mar 26, 2014
    9
    Managed to get a "34d" SMD removed and measured.
    It was 221kΩ.
    Apparently the first two letter "34" equate to 221 and the third letter "d" (small d) is the multiplier or 1000. D= 1000x.
    My confusion was seeing a small "d" marking. I guess they use a small "d" to avoid confusion with an "0" or "O".
    A "47d" is 301kΩ.
    Thank you for the help.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    These markings and their results are outside the scope of my experience.
    That's a nice way of saying, "Where in the world did anybody come up with a numbering system like that?" 474 means 470k Since when does 47 mean 301???
    RamaD likes this.
  7. HBN
    Mar 26, 2014
    9
    RamaD likes this.
  8. #12
    Nov 30, 2010
    16,705
    7,358
    Wow! A 3 digit numbering system. Such an improvement over a 4 digit numbering system!
    (This method describes 1% resistors.)
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    I vote for 472 - 4.7K. And the left joint might just be a proper miniscus curve.
    ak
  10. #12
    Nov 30, 2010
    16,705
    7,358
    One more way to obfuscate the circuits, as far as an old fart is concerned.:mad:
    All that back and forth checking to translate something we used to be able to read like English.
  11. ErnieM
    Apr 24, 2011
    7,443
    1,628
    I'm "meh" on both the EIA-96 marking method system and the need for it. It does allow marking on one size down from the present limit: I try to use size 0805 and up because these have a value marking.
    I hate that I now need a sheet of paper or an interweb to read a resistor value.
    All in all, I am glad I learned something.
  12. AnalogKid
    Aug 1, 2013
    4,709
    1,301
    I forgot about EIA-96. Haven't seen it yet in our inventory.
    The problem is speed. When you're making one million resistors per hour (!), the marking method has to be quick plys readable. 4 digits was barely ok on 0805 parts. There are at least 4 sizes smaller than that, and I've seen markings on two of them. I don't like EIA-96 because it isn't cyclic, but I grudgingly understand the need for it.
    ak
  13. #12
    Nov 30, 2010
    16,705
    7,358
    Makes me wonder why so many capacitors are not marked at all.:rolleyes:
  14. ErnieM
    Apr 24, 2011
    7,443
    1,628
    SMD caps come straight from the world of hybrid microcircuits, just change the termination metal and off you go. They have been that industry’s standard for several decades before using a SMD was common, an industry that traditionally never put a reference designation on anything (it needs room!) and never marked a component anyway (why when you screen on your own resistors?). Chips *sometimes* have a part number, but you need a 50x power microscope to see it.
    One analog guru I once worked with (now retired to Florida and I've lost touch) would purposely choose caps of different voltage ratings just to get different sizes for different values so a visual inspection would show placement problems: no “pick & place” for hybrids, it was all done manually, mostly with tweezers under a microscope.
  15. Ragwire
    Member
    Dec 9, 2013
    36
    It's the new, 21st century way...how could one expect it not to be a downgrade?
