Surface mount LED
Discussion in 'General Electronics Chat' started by kwstudz, Jun 24, 2009.
  1. kwstudz
    Jun 24, 2009
    I am looking for a surface mount LED of 0806or smaller with a less than 1.0 voltage drop. if anyone has any ideas thatd be appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    806 might be possible, but you may have to change some physics to get the drop as low as that.
  3. kwstudz
    Jun 24, 2009
    I meant 0805 or smaller
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No problem with the size compared to the physics. What color do you expect to get?
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  6. kwstudz
    Jun 24, 2009
    i needed a color of amber, yellow, orange, or a mixture
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    When you look at the page I gave you, yellow and orange leds will have a voltage drop of about 2.2 Volts.
    This will not meet your desired specs.
    Greetings,
    Bertus
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
  9. ELECTRONERD
    May 26, 2009
    1,146
    16
    Typical red LED's have a 3.2V drop which wont meet your required needs.
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    What?
    Ordinary red LEDs have a forward voltage drop of 1.5V to 2.4V at 20mA. 1.8V is typical.
    Very high power red Luxeon LEDs have a forward voltage of 2.3V to 3.5V at 1.4A. 2.95V is typical.
  11. ELECTRONERD
    May 26, 2009
    1,146
    16
    Well the 5mm LED's that I delt with say that they were 3.2V...Hmmmm......
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Generally the newer the LED the higher the drop, which also has to do with their higher efficiencies.
  13. tom66
    May 9, 2009
    2,613
    214
    The highest red LED voltage drop I've seen is 2.6 volts... Some newer ones might be higher, maybe 2.9 volts or so.
  14. ELECTRONERD
    May 26, 2009
    1,146
    16
    Hey Bill,
    Yeah, I got a few of the UltraBright LED's from SunLED that just came out.
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    Hadn't heard of them, point us to a spec sheet?
