sure electronics
Discussion in 'General Electronics Chat' started by acer, Oct 9, 2009.
  1. acer
    Aug 12, 2009
    6
    Has anyone bought anything from sure-electronics?
    Are they reliable as a seller in shipping and the quality of goods?
    They've got a 99.8% rating on ebay though. Just wanted to check with you guys!
    thanx in advance!
    OOPs sorry! Posted in the wrong category
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope. Do they have a website?
  3. mik3
    Feb 4, 2008
    4,846
    63
    If you want to be sure about the quality buy from large distributor companies like RS, Mouser, Digikey etc.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Agreed. I'm tending more to deal with Farnell these days.
    Dave
  5. mik3
    Feb 4, 2008
    4,846
    63
    I think Farnell is more expensive than the ones I mentioned.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The problem in holland with farnell is that they only supply to companies.
    As a single person they ask high administation costs, a minimum order and paying in advance.
    Greetings,
    Bertus
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I have not purchased anything from sure-electronics.
    If you have trouble with your order, you may or may not find language to be a barrier to successfully resolving your transaction.
    E-bay changed their policy on positive/negative reporting; negative reports were eliminated a year or so ago. Therefore, the vendor ratings on E-bay are now meaningless.
    If you want to be certain that the components you buy will perform to the advertised specifications and will be delivered to you in a reasonable amount of time, then you should buy from known authorized distributors from known manufacturers, such as Digikey, Mouser, Arrow, Avnet, Newark, etc. Otherwise, you are buying into an unknown. The performance of the components that you may (or may not) receive may well be marginal, or may not even come close to the specifications.
