supremacy of "C" in 8051 ????
Discussion in 'Embedded Systems and Microcontrollers' started by hharsshh, Aug 5, 2013.
  1. hharsshh
    Jul 20, 2013
    8
    why "C" is more used in 8051 microcontroller programming
    why can't we use "c++" language in 8051 ,even it is object oriented
    and successor of "C",,,,,,,,
    i waanna know it and other high level language like java ...
    pls clearly mention advntage and disadvntage of using both language .
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    The 8051 is very very old, still popular in India though. Almost all microcontrollers use a variation of ANSI C. There were other languages available but they never really took hold so ANSI C, Assembly and sometimes BASIC & Pascal are the only common choices.
  3. hharsshh
    Jul 20, 2013
    8
    hello sir , i m harsh,,,and i am new to microcontroller ,,,dont know any thing about it,,,
    xept little idea regarding them,,, i waana build carrer in this field only,,,so which controler i should use to learn embedded system,,,,, i have sound knowledge of c programming ,,,and a bit in c++....pls give me direction...
  4. Markd77
    Sep 7, 2009
    2,803
    594
    It doesn't really matter which one you learn, because the skills will be transferable to other chips anyway. I'd learn to use them with C and assembler, if you turn up at a job interview and can only use one or the other, and the next interviewee knows both then you are at a disadvantage.
    hharsshh likes this.
  5. hharsshh
    Jul 20, 2013
    8
    wats wrong nobody is replying ,,i need help,,pls ne bdy can asap...
  6. hharsshh
    Jul 20, 2013
    8
    but from which controller i shalll start ,,,,ur personal opinion,,,,
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Please use the full text in your questions.
    The SMS language is not good to read.
    Also use line breaks.
    Now you have one slurry of words.
    Have a look at the links of this page of the EDUCYPEDIA:
    http://educypedia.karadimov.info/electronics/pics.htm
    It will have information on some of the different kind of microcontrollers around.
    Bertus
  8. Markd77
    Sep 7, 2009
    2,803
    594
    I've only ever used Microchip, so I don't know the advantages / disadvantages of the others. I think all these manufacturers have reasonably priced programmers, free or cheap development environments (at least for assembler) and plenty of support and examples on the web:
    Microchip
    Atmel
    STMicroelectronics
    I'd start with fairly cheap and simple chips by one of the above then move on to ones with more features.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The 8051 lacks the resources to implement the constructs of C++. It also runs too slowly for most interpreted languages.
