I am about to build an OUTDOOR antenna amplifier. The amplifier will be screwed to the OUTDOOR antenna, but its power supply will be located INSIDE the house next to TV receiver. I'd like to use ONLY TWO wires to connect the amplifier to the indoor power supply and the TV.
Do you think the circuit below will work?
I use L1 and L2 (two big inductors) to prevent the high frequency signal being lost in the positive line. Those inductors are so big that they appear as a broken wire to the signal. On the contrary, the capacitors C3 and C4 appear as a short wire to the signal.
Do you think that the amplified signal will reach the TV receiver?
Thanks for your help.
PoRo
PoRo
