Supply Noise Battery Powered Circuit
Discussion in 'General Electronics Chat' started by Eoin_oc, Dec 1, 2015.
  1. Eoin_oc
    Oct 24, 2015
    23
    I have a homemade PCB that consists of a microcontroller connected to a CC2571 ANT+ transceiver. The CC2571 and micro are powered directly from the battery.
    The ANT transceiver has an internal processor and the radio is configured to transmit at 4Hz.
    It wakes every 250ms and does some brief radio activity. This includes a transmit and receive that cause a brief current drain of around 30mA for a few ms. In the off period, the radio consumes a few uA.
    This current spikes are putting a lot of noise on the supply rails of my PCB and I'm looking for a way to reduce it. When I look at the voltage off my 3V battery rail I see drops of around 100mV when the transceiver is active every 250ms.
    I also have a 2.5V regulator that powers some sensitive analog stuff and hanging off that there is load of around 7mA being switched on and off at approx 100Hz. This periodic switching puts even more noise on the 3V rail.
    On the 3V rail I have a high quality 100uF cap. Any tips on how the to reduce the noise on the supply rails?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    Try bigger filter caps on the regulator outputs.
  3. Eoin_oc
    Oct 24, 2015
    23
    The transceiver is powered directly from the 3V battery rail, but yes I can try a bigger cap on the 2.5 reg output
  4. dl324
    Mar 30, 2015
    3,378
    651
    Try it on the battery too.
  5. Eoin_oc
    Oct 24, 2015
    23
    How could I isolate the supply to the transceiver?
    I guess an LDO would only give isolation if I'm above the dropout voltage and I want the supply of CC2571 to be the same as the micro
  6. dl324
    Mar 30, 2015
    3,378
    651
    Capacitors are the easiest. Next step would be chokes. Does the supply noise cause problems?
    cmartinez likes this.
  7. Eoin_oc
    Oct 24, 2015
    23
    Putting a 100uF cap on 2.5 reg output has reduced the modulation on the battery rail down to around 25mV ripple.
    The 100mV spikes are still present from the CC2571 switching
  8. crutschow
    Mar 14, 2008
    13,501
    3,375
    Try connecting a 100μF electrolytic plus a 0.1μF ceramic cap directly across the power and ground pins on the CC2571.
  9. ronv
    Nov 12, 2008
    3,400
    1,457
    What kind of battery?
  10. ronv
    Nov 12, 2008
    3,400
    1,457
  11. Bordodynov
    May 20, 2015
    671
    194
    Putting a super capacitor on the battery.
  12. MrSoftware
    Oct 29, 2013
    545
    133
    I'm trying to learn so please forgive me if this is off the mark, but what about putting an inductor in line with the input to the 2571 to smooth the spikes, and add a cap across the source pins but with the cap + lead between the inductor and the 2571. Did I explain that clearly? My thought is the cap will maintain current to the 2571, and the inductor will smooth spikes to the rest of the system.
  13. crutschow
    Mar 14, 2008
    13,501
    3,375
    The problem with standard inductors is that they can resonate with the line capacitance in the system and can actually increase the noise or around that resonant frequency. Noise spikes can also trigger an oscillation around that frequency.
    To solve that, lossy inductors such as ferrite beads are sometimes used since they do not resonate with any capacitance in the system.
    MrSoftware likes this.
  14. ian field
    Oct 27, 2012
    4,447
    791
    Electrolytics are not so good with sharp transients - but you still need a few of them.
    Put disc or chip ceramics in parallel with the electrolytics - anything from 0.1uF to 0.47uF, these should be as close as possible to chip supply pins. Every chip should have at least one nearby.
    Others have suggested chokes - I'm thinking ferrite beads, less volt drop and they may be enough inductance for sharp spike suppression. They can be literally a ferrite bead on a bit of link wire, or a manufactured component that looks similar to a resistor.
