Supply 5V DC with USB Port
Discussion in 'The Projects Forum' started by luckycyq1010, Mar 24, 2016.
  1. luckycyq1010
    Feb 16, 2016
    I am trying to supply 5V DC to a circuit that has a couple of ICs with a USB Port.
    Are these all I need?
    USB to 3.5mm barrel cable
    3.5mm barrel power jack
    a decouple capacitor
    If someone can also recommend some parts, it would be appreciated.
  2. ISB123
    May 21, 2014
    1,240
    531
    That should be it.
    luckycyq1010 likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    You can get a USB cable that most likely will come with a Mini USB on the other end, you can replace this with the barrel jack.
    You don't show your Country of origin but Digikey have the parts.
    Max.
  4. wayneh
    Sep 9, 2010
    12,394
    3,246
    Pay attention also to the dimensions of the jack's male and female parts. The diameter of the center hole is also important, and even the length of the barrel. Details matter.
  5. luckycyq1010
    Feb 16, 2016
    Hi Max,
    I live in the US
    Thx
  6. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    You can pick up a USB cord locally or off ebay, the barrel jack and plug are stocked by Digikey, just search Barrel Jack.
    Naturally only the +5v and common conductors are used on the cord.
    Max.
