The manual states I need the following analog power supply:
http://www.ebay.com/itm/Universal-2...-Driver-110V-240V-for-LED-Strip-/351139238715
Can someone confirm that this will work, and describe the circuit needed?
0.3A @ +12 to +15V (4.5W)
0.25A @ -12 to -15V (3.8W)
The positive supply – +12V to +15V – should be brought in on the A+15V line on pin 59.
The negative supply – 12 to -15V – should be brought in on the A-15V line on pin 60.
The analog common should be brought in on the AGND line on pin 58.
I plan on using the 34V 3A version of this:0.25A @ -12 to -15V (3.8W)
