Hi, in the attached circuit how would you find the voltage across the open circuit BD using superposition. Can someone explain the steps to me as I'm not sure how to do an example like this.
Superposition would give you the voltage that you would measure at the junction of the two resistors.So, you would short circuit each source, one at a time. How would you find the voltage through the open circuit. Would you short that aswell when you analyse the problem. Can someone explain this to me. Thanks.
by Jake Hertz
by Jake Hertz
by Duane Benson
