Superposition theorem
Discussion in 'General Electronics Chat' started by alamin2500, Oct 12, 2013.
  1. alamin2500
    Oct 12, 2013
    Q) Use superposition to find Vx in the circuit in figure below?
      File size:
      22.3 KB
      26
  2. WBahn
    Mar 31, 2012
    18,088
    4,917
    Yes. Use superposition to find Vx in the circuit in the figure below.
    Which node if your reference node? This is important because your Vx is indicated as being a node voltage, but node voltages only have meaning relative to a reference node.
    Now, how about actually making an attempt to solve YOUR homework problem (and this post should be in Homework Help). That will give us a starting point to help guide you toward finding the solution.
    alamin2500 and anhnha like this.
  3. alamin2500
    Oct 12, 2013
    Plz briefly solve this problem with equation.
  4. WBahn
    Mar 31, 2012
    18,088
    4,917
    Would you like us to submit it to your instructor for you, as well?
    Apparently my message was a bit too subtle.
    First, YOU need to show YOUR effort to solve YOUR homework problem.
