supernodes - KCL?
Discussion in 'Homework Help' started by mccormick.cj, May 27, 2008.
  1. mccormick.cj
    May 25, 2008
    10
    hey guys, one more question. sorry, not trying to abuse the system.
    is anyone familiar with supernodes in circuit analysis with KCL?
    and if so, are they even that useful?
    thanks
  2. haditya
    Jan 19, 2004
    220
    supernode is just a convenient technique of eliminating one equation from the nodal analysis equations. It is usually not needed.
    What is generally done is two (non - reference nodes) between which an souce is connect is considered as a supernode and currents entering the super node is equated to the current exiting the supernode as is done in nodal analysis.
    For more and an example, you can refer to Hayt, Kimmerly, Durbin, Engineering Circuit Analysis
    Supermeshes are similar only they involve a current source between two meshes.
  3. mccormick.cj
    May 25, 2008
    10
    in your opinion, are the supernodes easier to work with, or more trouble than they are worth? I have learned about supermeshes and that method does come in handy on occasion.
  4. haditya
    Jan 19, 2004
    220
    the thing is.... you eliminate one equation (for every supernode) without having to wite it down. So yeah in that sense it does come in handy.
    however if you fail to account for them in a circuit, you wouldnt go wrong in normally solving them using nodal analysis and an unknown value of current through the voltage source. Two of those equations will have that unknow current tern that you can eliminate. this will eventually lead to the supernode equation
  5. mccormick.cj
    May 25, 2008
    10
    ok sounds good, thanks alot
