Use the node voltage method to find how much power the 2 A source extracts from the circuit.
Okay, I figure I will find the power dissipated at each resistor, and use that to find how much the 2A source is extracting from the circuit.
I redrew the circuit so I could use the supernode a little easier. I chose the bottom node to be my reference node, and the supernode would fall between node's 2&3. HOWEVER, I am very, very weak with this concept of a supernode, so hopefully you can steer me in the right direction.
At node one, we have
\(\frac{V_1}{50} + \frac {V_1-V_2}{1} - 2 = 0 \)
And the supernode equation, I came up with...
\(\frac{V_2-V_1}{1} + \frac{V_3}{4} = 0 \)
Now, I have no idea what to write as my third equation. There are no dependent sources to use to create a constraint. Where can I use the 45 V? Should I set my supernode equation equal to it?
