superheteordyne radio receiver
Discussion in 'Homework Help' started by Kldnz, May 5, 2016.
  1. Kldnz
    Feb 8, 2016
    17
    hello I need a superheterodyne radio receiver with all the parts... can any 1 help me with that? I don't need a very complex one a simple one would work to I just need it to have all the main parts like the detector heterodine filter etc... don't know all the names of those components because English is not my native language.
  2. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Build each block according to your desired outputs.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    thumb2 likes this.
  4. crutschow
    Mar 14, 2008
    13,509
    3,385
    If you are working in the 1MHz AM band then all the stages could be build with low-noise, high frequency op amps with a multiplier for the mixer.
    thumb2 likes this.
  5. Kldnz
    Feb 8, 2016
    17
    sorry for misunderstanding but i need a real circuit with real elements transistros diodes etc. and it needs to be a real radio receiver. but not a very difficult one. it should include amplifier, mixer(with heterodine or sepereate ones) decoder filter etc... sorry for not telling u that... and it should not include any microchips if possible...
  6. JoeJester
    Apr 26, 2005
    3,403
    1,227
    q
    I'll assume this is for you to get a grade. The onus is on you to do the work, as the membership here can, upon receipt of your work, advise you whether or not it works as you want it to.
    Here's a link to an AM-FM superhet kit
  7. Kldnz
    Feb 8, 2016
    17
    No. I don't need it for a grade i just need a real circuit and then in a test 2 weeks from now i'll need to draw out certain parts of it like mixer decoder. I can tell which parts it is and how it looks and after what it goes... But googling a circuit is really
    Hard because it shows complex ones and i don't need a complex one. So thaths why I'm asking here. Because i can't find a simple
    Circuit anywhere;(
  8. BR-549
    Sep 22, 2013
    2,184
    421
    Can you give us an example of what you think a simple circuit is?
    If the circuit has to be a superheterodyne radio receiver, it will NOT be simple. At least for me.
  9. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Ok, you are doing it for a grade in two weeks when you draw it out and probably explain it.
    I gave you a block diagram in the second posting and here is an AM superhet receiver kit manual. You can associate portions of the schematic to each block, and then proceed to study.
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  11. Kldnz
    Feb 8, 2016
    17
    I need to find a circuit on the internet. So i thought of asking here. I don't need to draw it myself since we didn't learn abou all the parts yet.
  12. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Just where did you think I found that manual? It was on the internet. All the circuits in a superhet are on that schematic. Read the last manual I gave you.
    panic mode likes this.
  13. Kldnz
    Feb 8, 2016
    17
    http://imgur.com/DdEyvLT
    So this is the circuit thanks to JoeJester thank you. And i marked some parts of it and i will name it and can anyone tell me if I'm correct or not?
    marked red is the entering circuit the signal comes through here
    Green is the frequency changer maybe with superheterodyne im not totally sure about this...
    Purple is 2 stage amplifier which amplifies the lets say 455kHz signal? right?
    and then black is detector which detects the signal? but I'm not totally sure from which side the signal comes to detector after the amp or from frequency changer (mixer) I will need to draw one of these parts for my test so i wanna make sure I got this right...
    Also I will need to draw a simple superheterodyne circuit Uploading the picture is this draw right?
    http://imgur.com/nCrap8V
    Thank you for all the help can some one help me with this the test is in 5 days... and I wan't a good grade...
  14. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Can you tell me about the word hetrodyne .... And why the receiver is a super hetrodyne?
  15. Kldnz
    Feb 8, 2016
    17
    It's the thing that adds another frequency to the mixer. Different from the signal frequency.
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    If you want to know more what is happening in the mixer, read the attached PDF's.
    Bertus
  17. Kldnz
    Feb 8, 2016
    17
    I actually don't need information about it but i will read it. I just need to know if i marked the parts in the picture are right and if i drawn a correct circuit. Thaths all.... Can anyone answear me that?:/
