Superconductor conductivity
Discussion in 'Homework Help' started by Majith, May 23, 2015.
  1. Majith
    May 23, 2015
    Does a superconductor looses its superconductivity in high currents?
  2. Kermit2
    Feb 5, 2010
    3,851
    967
    low temperature allows superconductivity. Heat increase would move the conductor out of the superconductivity temperature range.
    Heat is produced in a conductor via current flow and resistance. I(squared) x R.
    If R=zero, then no amount of current could produce heating which would move the conductor into the non superconducting temperature range.
    Majith likes this.
  3. OBW0549
    Mar 2, 2015
    1,395
    941
    Your question is addressed in this article:
    http://www.allaboutcircuits.com/vol_1/chpt_12/7.html
    The short answer, if I'm understanding that article correctly, is "yes."
    Majith likes this.
  4. Kermit2
    Feb 5, 2010
    3,851
    967
    The article states that magnetic fields are the culprit.
    Since large current flows produce large magnetic fields, then, yes. However it would not be the current which does it, but the resulting magnetic field.
    Majith likes this.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    There are four basic parameters that influence a superconductor: temperature, magnetic field, current density, and mechanical stress. There is a critical value for each of these above which the superconductor cannot be in the superconducting state. That critical value is a function of the other three variables. So increasing the temperature lowers the critical values of the other three. Similarly, increasing the current decreases the critical values of the other three.
    Majith likes this.
  6. Majith
    May 23, 2015
    Thank u guys..that would be helpful to continue!
