Hello I have been messing around with the vizimag trail and have found something interesting.
the question is will a superconducting coil with the same current as a normal conducting coil create the same field strength. because in the program the superconductor is like 1000 to 10000 time weaker in producing force on another magnet and it's field strength as well?
can someone explain to me why this is, I would expect it to at least produce the same field strength as the normal coil at the same current.
