Hi, I did an experiment to compare voltage drop for two cases. First case, a supercapacitor (1F rated at 3.6V) is charged up to 3.6v and connected to a load. Second case, two supercapacitors (1F rated at 3.6V each) connected in parallel, are charged up to 3.6v and connected to the same load. In the first case, I observed a drop of 0.37v after 24 hours. In the second case, I observed a drop of only 0.05v after 24 hours. I am a novice at this and find this quite puzzling. What are the possible explanations for the superior performance for the parallel configuration? Thank you.
