Ugh... The more I look around the more lost I get
I'm confused. This arrangement has the equivalent capacitance of 857 F. If you distribute the voltage equally, your supply would be 17.5 V (7 * 2.5 V).2. I guess I'm not seeing the issue? 7 paralleled pairs wired in series. Arranged that way to fit in my space constraints. It looks a bit funky but it functions as intended
Short them with a screwdriver and see how much shorter it is after the shower of sparks has settled.I'm confused. This arrangement has the equivalent capacitance of 857 F. If you distribute the voltage equally, your supply would be 17.5 V (7 * 2.5 V).
How do you calculate the amount of power in the capacitors?
Are you taking up welding? It works better with a car battery.Short them with a screwdriver and see how much shorter it is after the shower of sparks has settled.
And if I were to limit to 2.4v it would be 16.8v. If I were to go to the absolute maximum they would be at 18.9v.I'm confused. This arrangement has the equivalent capacitance of 857 F. If you distribute the voltage equally, your supply would be 17.5 V (7 * 2.5 V).
I guess what I want to know is how much power can you get from this configuration. If you have a load that requires 100 mA, how long will it be powered?And if I were to limit to 2.4v it would be 16.8v. If I were to go to the absolute maximum they would be at 18.9v.
I guess I'm really not sure what you are asking?
Ideally I'd like to have the power distributed as evenly as possible regardless of voltage
Is this for 1 capacitor, or for the bank of capacitors as he has them arranged?At 2.7V and 3000F, that's 2.7V x 3000F = 8,100 coulombs = 8,100 amp-secs or 2.25Ah.
But again, you cannot then simply multiply by the starting voltage to get power. You need to integrate the area under the curve. Or you can cheat and use the formula. It's almost 11kWs
Yeah, for this kind of current I think you're exactly right.Instead of balancing, don't you "just" need a way to stop charging when any individual cell reaches the target voltage?
Apparently supercapacitors are pretty critical on working voltage, add to that tolerances on capacitors in general is pretty wide - its easy for a capacitor in the chain to end up charging to a higher voltage than designed for.Okay I see they are connected properly. My apologies.
Now. Is this some kind of new capacitor that utilizes a chemical reaction?>
Won't the charge self distribute among the capacitors? why the need for 'balance'? Again, these are not chemical powered are they? They simply store energy in the form of an excess of electrons gathered on the surface of a conductive material.
That does not sound possible (to me). The thing that seems most relevant is that voltage in a capacitor bank is a dependent variable - charge is the determining factor.Reason I picked 2.4v is suppose I were to limit each cell to 2.7v, would it not be possible, in theory, to have the bank charged to 16.8v, 6 capacitors charged to 2.7v, 1 charged to .6v. then if the bank were to drop below 12.6v, it would cause the final capacitor to reverse charge, damaging it I've been able to do that when playing around with smaller capacitors, but haven't had the balls to try it with these
by Aaron Carman
by Jake Hertz
by Robert Keim
by Aaron Carman
