I've got this homework problem of Super Position and i'm stumped, because the problem is laid out totally different than any other peoblem in the book or online.
The problem is "using super position, determine the current through the 12ohm resistor."
My question to you guys is.. Can I switch the 10V source with the 2ohm resistor over to the right and move the 12ohm resistor in the middle of the two, to make it look like every other problem out there? If this is possible, I think I can go about doing Super Position.
