Hello I cannot figure out this question and need a little help
R Thread Starter ratz4 Joined Feb 8, 2014 1 Mar 16, 2014 #1 Hello I cannot figure out this question and need a little help Attachments IMG_0055.jpg 292.8 KB Views: 32
Jony130 Joined Feb 17, 2009 5,488 Mar 16, 2014 #2 Simply replace 4Io CCVS with a short circuit. And treat V1 and V2 as a one big super node. So you need to write two nodal equation and one additional for a supernode V2 = V1 - (4 * V1/16) Or try to watch this video https://www.youtube.com/watch?v=NA_zlZTDiKU
B BytetoEat Joined Mar 5, 2014 25 Mar 17, 2014 #3 Uhm do NOT replace the dependent voltage source with any wire, def wrong to say that conceptually. however you can make a super node out of v1 and v2, because you know the voltage difference between them is always (4Xi0)Volts.
