Super new "circuiter" here, a few basic questions...
Discussion in 'General Electronics Chat' started by captjack, Nov 2, 2014.
  1. captjack
    Nov 2, 2014
    5
    So I'm trying to build something that senses light and then heats up a nicrome wire.
    Questions:
    • Right now, I'm thinking a photoresistor that can activate a relay once light is shone on it. Viable?
    • Do relays have a minimum current threshold, i.e. if I run .0001 mA through a relay will it still switch?
    • Am I right in assuming that if I just have a photoresistor and a nicrome wire in series with a 9V battery, the current will be too low to actually heat up the nicrome enough? (around 150-200 Celsius) 32 gauge nicrome, about 1 inch length, photoresistor at min resistance around 1000-2000 ohms.
    • Is this a viable:
    • Photoresistor in series with relay, connected to 9v batter
    • Relay switches on a branch with nicrome wire and another 9v battery
    And finally, any suggestions on how to get a light dependent resistor to activate the heating up of a nicrome wire? Thanks!
  2. captjack
    Nov 2, 2014
    5
    I should note this is for a science project, where I'm not allowed to use integrated circuits and maximum voltage is 10V.
  3. Lundwall_Paul
    Oct 18, 2011
    222
    19
    First thing to do would be to gather the specification sheets for the relay, photo resistor. .0001 mA is .1 micro amp which is .0000001 amps. This won't energize any relay. The spec for your relay will tell you the minimum current/voltage needed.
  4. Lundwall_Paul
    Oct 18, 2011
    222
    19
    If you need help finding specs please include manufacture and part number.
  5. ISB123
    May 21, 2014
    1,240
    531
    You are going to need at least 50-100mA to trigger a small 9V relay.Average photoresistor from radio shack is going to have 10K~ when on and 100K~ resistance while off.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    That is more electro-mechanical approach.
    A purely electrical apporoach would be to use transistor instead of relay.
  7. wayneh
    Sep 9, 2010
    12,371
    3,224
    That should be OK. One or two transistors should be all you need. The photoresistor current is tiny and needs to be amplified in order to trip a relay. The degree of amplification - determined by the specs that have been requested - will help you decide how much current gain you need, and how many transistors you need to accomplish that.
  8. #12
    Nov 30, 2010
    16,664
    7,311
    Here's one way to do it.
  9. captjack
    Nov 2, 2014
    5
  10. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    32g Nichrome is ~10.6ohms/ft so the load is going to be high (10amps) for a 9v battery.
    Max.
  11. ISB123
    May 21, 2014
    1,240
    531
  12. captjack
    Nov 2, 2014
    5
    I'm sorry but how exactly does a transistor increase the current output?
  13. ISB123
    May 21, 2014
    1,240
    531
  14. captjack
    Nov 2, 2014
    5
    Hmmm.. So for that website if I replace the LED with a relay and then attach a branch with a battery and nicrome wire it should work? And again thanks for all the help, this stuff is really hard for me!
  15. ISB123
    May 21, 2014
    1,240
    531
  16. Sensacell
    Jun 19, 2012
    1,183
    276
    A standard 9 volt battery has a large internal resistance, not capable of putting out enough current to heat nichrome wire.
  17. joeyd999
    Jun 6, 2011
    2,756
    2,916
    Excuse me???
    Granted, it's not nichrome, but it clearly rebuts your claim.
  18. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    I doubt 1" of 32g nichrome at 10 amps will cut it?
    Max.
  19. Sensacell
    Jun 19, 2012
    1,183
    276
    Love the video- forgive my loathing of 9V batteries.
  20. wayneh
    Sep 9, 2010
    12,371
    3,224
    It doesn't, really. It allows a small current to control a larger one. The energy and current comes from your power supply. The transistor acts like a light dimmer switch, where a small input (your hand on the dial) controls power to the load.
