Super NES Timer
Discussion in 'Embedded Systems and Microcontrollers' started by Moonstar78, Jul 11, 2011.
  1. Moonstar78
    Jul 7, 2011
    Hi every one.
    I need your help guys... hope to solve my problem with things.
    I bought a SR-1210 coin slot, Super NES Timer and a 12vDC supply. I want these things be configured and operate. i have no idea how does the TIMER circuit works. I tried to connect the timer circuit board on my 12vDC p-supply but it does not show if it working. The 3-digit 7 segment display won't light..
    Does anybody, can give me the right connections of these things to make it work...
    Thanks in advance and more power! :)
  2. guitarguy12387
    Apr 10, 2008
    We need more info to help! This is too generic. Part numbers, photos, schematics, wiring diagrams, code, etc...
    Good luck
  3. sj666
    Jun 23, 2011
    Hello. I also recently saw piles of SNES Boards at an electronics store and I am very curious how it is operated and what is the large IC installed on this board? I wonder if these are the same boards that Moonstar78 is referring to.
    I am working on a project to which I plan on using these boards...Where can i find an schematic of this? I cant seem to find any help on the web, i hope it will be available in this forum.
    I have noticed, some of the components are:
    DIP Switch
    3 Seven Segment Displays
    A Crystal Oscillator
    7805 Voltage Regulator
    and several semiconductors
    Thanks very much.
