I need to use a few drops of super glue every week or two sometimes I'll get a project where I use 1/2 of one of those mini tube (2 gram tubes). It seems no matter what I do, how quick I put the lid back on, how tight it is, the glue dries out before I use it again. Once in a while, I can squeeze a little out. The best for "keeping" is "The Originial SUPER GLUE" Gel. IT seems to not dry out as fast in the metal squeeze tube.
I'm wondering if anyone has any suggestions on how to make this stuff store better. I've seen 1/2g tubes (super small tubes, almost worthless if you spill a drop). Then there are the plastic containers (maybe 14-20g) where the sides "squeeze" some and it comes out the nozzle. Then there are some that are 4-6g and I've tried these and they get dry real quick too. I just don't know if there is a trick or one brand is better or what.
I'm also wondering if there is anything comparable to JBweld. I've used it on a number of occastions and it is pretty nice stuff but it gets pricey at $8 / 2oz. I'm not trying to be cheap as I think JB weld deserves business as it has a good product. The problem is that I don't have the $$ so I have to find alternatives to make due.
If anyone knows anything about 2 part epoxies that use Bisphenol-A (BPA) and epichlorohydrin (at least that is what the MSDS said on my 2 part 50/50 epoxy (dried clear and is pretty/very hard). Is it really just those two chemicals mixed for an epoxy of some kind (there are many different epoxies). I have also seen some that are 99.9% from one bottle, then a few drops of hardener - MEKP (methyl Ethyl Ketone Peroxide). Can that be added to the BPA/Epichlor mix to make it even harder?
Sorry if this isn't so much "electronics" but I have found a need for glues and epoxies very often when working with this stuff. I thought some of you may be knowledgeable on this.
