super fun super positioning theory, help needed!
Discussion in 'Homework Help' started by sloppygiuseppi, Mar 31, 2008.
  1. sloppygiuseppi
    Mar 30, 2008
    6
    If anyone is good at this, please complete, will be hugely appreciated.
    OK so for the circuit attached;
    Using super positioning theory, calculate the following:
    1. The current flowing in the 10 Ohms resistor.
    2. The power dissipated in each of the resistors in the circuit.
    This is the last question i need help with, please help me.
  2. techroomt
    May 19, 2004
    198
    what have you been able to calculate so far? is this homework?
  3. mik3
    Feb 4, 2008
    4,846
    63
    use star-delta transformations to transform the delta combination of resistors
    20, 20 and 10 Ohms to a star combination and you will be able to solve it
  4. veritas
    Feb 7, 2008
    167
    for the 10 ohm resistor, it gets really easy when you start shorting the sources for superposition.
    The 5V source contributes nothing (the terminals of the resistor are shorted
    The 20V source is in parallel with the resistor.
    The 10V source is in parallel with the resistor.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
