Hello, I am currently apprenticing as an electric motor systems tech and I am learning about the power characteristics of three phase induction motors. I have learned that one Horse Power is equal to 746 Watts of true power and from that I can determine the Wattage consumed by a motor. Given the formula P=E(squared)/R I can then find the resistance of the windings. This suggests that HP is derived directly from resistance of a motor.
So if a motor was wound with super conductors, therefore having zero resistance and consuming all quadrature power and no true power, would the motor run and if so how would you calculate the HP output?
Thanks for any help,
Kevin.
Kevin.
