I am an electronics enthusiast and am trying to build a circuit which senses the light from the sun. When the light intensity of the sun reduces (during sunset) below a certain level it triggers on a light.
I was thinking of using an LDR since precision is not required here. The output of the LDR is compared with LM311 voltage comparator.
The LM311 is then connected to a NOT gate to invert it.
I am wondering what the output at NOT gate will be. And further can this output be used to trigger a switch for the lighting the AC bulb??
Thanks in advance!
Thanks in advance!
