Sump Pump Well LED Level Indicator
Discussion in 'The Projects Forum' started by trailmixhawkeye, Jun 12, 2013.
  1. trailmixhawkeye
    Jun 12, 2013
    5
    Wondering if someone can help me with building an inexpensive Sump Pump Well Level Indicator.
    I want it to run off of a 9v battery.
    I want it to have four LEDs. Green = Empty, lowest point in well, then three Yellow LEDs showing the various levels, and then a RED LED to show the highest level.
    ideally, would like to have an alarm buzzer if the level opens the Red led circuit.
    I found this on google but it seems to run on 6v ac and I want mine to be 9v dc.
    http://www.projectsjugaad.com/electronicscircuitsdiagram/Water-Level-Indicator-with-alarm-Melody-generator-for-greeting-cards-Brakelight-Flasher-Car-anti-theft-wireless-alarm.html
    I'm hoping someone can help me out and guide me to how to build and get parts, etc.
    I can solder and can follow instructions but do not know schematics fluently.
  2. trailmixhawkeye
    Jun 12, 2013
    5
    The reason I want one of these is my sump pump well is a sealed one so if I want to know if it has any water in it I have to open it up which requires removing 6 screws. It is a PITA as I have to move stuff out of the way, etc. I know I am being lazy but should be a simple project I think.
    I'd just like to have something hanging above it with a level indicator by LEDs. quick and simple using water level to close the various level circuits.
  3. wayneh
    Sep 9, 2010
    12,403
    3,251
    I think a LM3915 "VU meter" would be perfect for the display. The question is how to feed it a voltage that is proportional to level.
    I assume your sump pump has a float to activate the switch. Maybe you could use that somehow.
    Are you sure about the 9V battery? It won't last all that long, which sort of defeats the purpose of anything dealing with a sump pump.
  4. KMoffett
    Dec 19, 2007
    2,586
    234
    The circuit you linked to is powered by 6VDC, not 6VAC. With proportionally changing some resistor values, it would work on 9VDC. If that circuit is powered continuously the electrodes that are continuously submerged will corrode due to electrolysis. However, if it is only powered when you want to check the level, i.e. press-to-test, that will not be a problem. This, however this will not allow for an unattended alarm. I would use that circuit for the water 4 levels. I would add another circuit with two electrodes at the alarm water level point. Though "powered" this circuit would not draw any current until the alarm level was reached.
    Ken
  5. trailmixhawkeye
    Jun 12, 2013
    5
    Thanks for the replies... few questions.
    1. If it is powered all of the time, ie. 6VDC, how does one avoid the electrolysis? Or is that not a possibility?
    2. Per that design what do I use to power it with 6VDC? Some sort of AC to DC transformer?
    3. Given the link I posted does the full circuit need in modifications in order to add a buzzer to it?
    3. Where is the best place to buy these electrical items to build this design?
  6. KMoffett
    Dec 19, 2007
    2,586
    234
    1. Use AC drive with stainless steel electrodes. That would be a different circuit.
    2. Yes
    3. The circuit you posted has a buzzer.
    3. (#2 ;) ) Mouser, Jameco, Radio Shack...
    Ken
  7. trailmixhawkeye
    Jun 12, 2013
    5
    Where would one get stainless steel electrodes?
  8. trailmixhawkeye
    Jun 12, 2013
    5
    Also, does the 6VDC Plug In AC Adapter need to have a millamp rating too or any 6vdc will work?
  9. Dodgydave
    Jun 22, 2012
    5,167
    777
    Here is a good level detector circuit i have built in the past.
    Or this one circuit uses a 0-9 display
  10. KMoffett
    Dec 19, 2007
    2,586
    234
    That one also would suffer from electrolytic corrosion of the electrodes due to the high DC drive current on continuously submerged electrodes.
    Welding shops
    The most current will be drawn when the buzzer is on. I would say any 6VDC wall wart with a current rating of 200mA or more.
    Ken
  11. gerty
    Aug 30, 2007
    1,154
    304
    I built one years ago using a stainless TIG welding rod. They are about 3 ' long 1/8"dia and I cut one up to meet my needs.
  12. KMoffett
    Dec 19, 2007
    2,586
    234
    This a version of a circuit I've used in the past. It uses AC drive on the electrodes to prevent corrosion. It has 6 levels, but you can reduce the configuration to meet your needs. Note that the LEDs are high brightness types that require only 2mA to get a bright output.
    Ken
  13. Externet
    Nov 29, 2005
    781
    58
    Any project needs details disclosed to be able to suggest best options for it.
    If you have room in the well to fit a PVC pipe all the way down, five of these could be nested inside at the desired spacing and each will signal a LED or buzzer at the surface, with no corrosion problems.
    http://i00.i.aliimg.com/photo/v0/405215382/Mini_Float_Switch_plastic_type_.jpg
    They are sealed reed type, with a sliding magnet float collar.
    A supplier:
    http://www.deeterelectronicsinc.com...es-vertical-liquid-level-sensors-float-switch
  14. wayneh
    Sep 9, 2010
    12,403
    3,251
    An "electrode" can be any piece of stainless steel. Your local hardware store will have a selection of stainless steel hardware that you might consider. I'm wondering if stainless wire rope might not be the cheapest form you can get.
    But you might also want to think about other detection methods. For instance, there is this, and I recall a thread in this forum that discussed a sort of "tape" that generated a variable signal based on pressure I think. I guess any pressure sensor in the bottom of the sump hole would tell you how much depth you have.
  15. gerty
    Aug 30, 2007
    1,154
    304
    This is by far the easiest to impliment. Each switch can turn on its own led.
  16. crutschow
    Mar 14, 2008
    13,518
    3,386
    Just because it's stainless steel doesn't mean it can't corrode by electrolysis as noted here. Better to use carbon electrodes such as these, or perhaps copper with AC excitation.
  17. wayneh
    Sep 9, 2010
    12,403
    3,251
    Yeah, I think fouling by lime scale and other goodies in sump water are far more trouble than corrosion. Think bio-slime. The electrodes could be solid gold bars but they still wouldn't work if they're buried in a layer of goo.
