I want to install a sump pump backup in my basement - When it rains a lot, my main pump kicks in quite often
I have a generator, but I am not fully covered if I am not here when power goes down, or if my main pump fails
So I want a battery operated backup
I have 2 options: a 12V system (such as Wayne ESP 25 or Watchdog basement) directly powered by the battery, or a regular sump pump (110 VAC) powered by the battery thru an inverter (1,200 or 1,500W I guess)
But Ive heard that the inverter option will give less autonomy, since the inverter itself will consume energy even at idle, and is not 100% efficient either
However, how can I find out the difference in terms of autonomy: is it going to be only few % less with an inverter, or the impact is much bigger than that and I am better off with a 12V pump?
