Summing Amplifier
Discussion in 'Homework Help' started by Hurt_it_Circuit, Nov 5, 2012.
  1. Hurt_it_Circuit
    Oct 2, 2012
    53
    How do you create an inverting summing amplifier on a breadboard? I have all of my connections to the om amp correct. I am unsure of where I connect my 2 power sources, my + input source, and my two - input sources with two batteries. I have tried numerous combinations and nothing has worked please help
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post your schematic
  3. Hurt_it_Circuit
    Oct 2, 2012
    53
    here you go ... The resitors are in series to give an Req o 40k Ohms on top and 25k Ohms on the bottom
    the gray wire in the bottom right corner is my V out
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    What you have posted is a wiring diagram.
    A schematic was asked for.
    Can you post the schematicof the circuit?
    Have a look at this page of the eBook for some ideas:
    Averager and summer circuits
    Bertus
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Here is an example. Remember GND, +9 volt and -9 volt. Should be connected to your breadboard
  6. Hurt_it_Circuit
    Oct 2, 2012
    53
    I calculated Vout to be -2.85V ... But I am having difficulty assembling this one my breadboard. I have 9V sources for the power but I do not want to waste the battery which is why they were not in the picture
    sorry here is actual drawing
    I have the power connected like that and I am assuming that the positive input also connects to the ground ... but what about the sources ?
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The - side of the sources should go to ground, when the source is positive.
    Bertus
  8. Hurt_it_Circuit
    Oct 2, 2012
    53
    so you are saying to connect everything to ground when the sources are generating a positive current? But doesn't this short circuit the system cause I am getting a value of zero when i do that
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    You did not post a schematic, instead you posted a fuzzy photo of a breadboard circuit.
    We do not know if you are using an opamp since it does not have a part number, it might be an LM386 power amplifier IC and its pin numbers are different to the pin numbers of an opamp.
    I am attaching a real schematic of an audio mixer circuit. It can drive a load not less than 22k ohms (the 330nF output capacitor C3 has a cutoff frequency of 22Hz with a load of 22k).
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    I see that you are summing DC voltages, not audio. Your answer is correct.
    Here is the schematic of your circuit (but it is missing the power supply):
    Hurt_it_Circuit likes this.
  11. Hurt_it_Circuit
    Oct 2, 2012
    53
    It seems to be working when I measure. I connected all the terminals to the negative. The only issue I have is that my measured values or off by a tens place. Everything else is correct my sign and the numbers ...
    Nevermind made a dumb mistake was using wrong resistor value
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    What are "the terminals"? The inputs?
    What is "the negative"? The negative 9V supply?
    What is "or off"? Do you mean are off?
  13. Hurt_it_Circuit
    Oct 2, 2012
    53
    made a silly mistake in circuit diagram measured values are equal to calculated values now
  14. atferrari
    Jan 6, 2004
    2,672
    785
    It is common practice with opamps to identify inverting and non inverting inputs. No matter what you asume.
