Summing amp inputs for an ADC
Discussion in 'The Projects Forum' started by Adam Fish, Dec 2, 2015.
  1. Adam Fish
    Nov 13, 2015
    7
    Hi, I am currently trying to create a system of a ADC including a summing amp along with latches. But my question is that what are the two or more inputs of the summing amp if i'm getting a single signal output? Also another question that i need answering is how do i use differential amplifiers to create two outputs from one single input? This was supposed to include bilateral switches but i'm unsure. Here is a picture of my block diagram. Help.
  2. crutschow
    Mar 14, 2008
    13,472
    3,359
    If you don't have two signals to sum then you don't need a summing amp.
    Differential amps have a differential input (2 inputs), normally not two outputs.
    Why do you need two outputs? A single output can go to more than one place.
    What would the bilaterial switch do? Who told you to include those?
    You seem to be putting together random technical terms without understanding what you are trying to do.
    If you can explain the purpose of the circuit and all the blocks then we can better help.
    This sounds like homework.
  3. Adam Fish
    Nov 13, 2015
    7
    Well my circuit is supposed to be that when the temperature gets to a certain point to a degree the fan will turn on. Anything lower the heater turns on. They can't both be on so that's why I use the differential amplifier. Also the 7 segs are to display the temperature. Does that help
  4. GopherT
    Nov 23, 2012
    6,300
    4,020
    @Adam Fish
    You could do this quite easily with an ILC7107 and ADC with direct output to 7-seg display. and an LM35 or LM34 Temp chip (reads degrees as millivolts).
    Add a comparitor to the temp chip to get your switching. Everything with three chips.
  5. Adam Fish
    Nov 13, 2015
    7
    However this circuit is supposed to have 5 subsystems where I can do 2 tests on each one
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    Ah! Nice to know Rube Goldberg is still influencing system design. ;)
  7. crutschow
    Mar 14, 2008
    13,472
    3,359
    Where is it stated that you need 5 subsystems?
    If you post the exact requirements, then we can better help you.
    Otherwise we're just going in circles. :rolleyes:
  8. Adam Fish
    Nov 13, 2015
    7
    I've got to make a circuit with 5 separate systems all connected that can be tested on their own. In the block diagram I do 5 of those and I'm making a circuit with a temperature sensor affecting the outputs of a motor and a heater. There?
