Please don't just give out answers. Hints, suggestions, leading questions are great, but just giving answers seldom helps the TS learn anything other than how to get other people to do their work for them.X=AB(!C)D+AB(!C)(!D)+(!A)BCD+(!A)BC(!D)=AB(!C)(D+!D)+(!A)BC(D+!D)=AB(!C)(1)+(!A)BC(1)=
AB(!C)+(!A)BC = B(A(!C)+(!A)C) => Gates And( B, XOR(A,C))
+ = OR; AB=A&B; &=AND; !A=NOT(A) .
It's not really an answer, but you wouldn't necessarily know that unless you knew how to do the problem. IIRC disinformation was a standard product of the cold war. Two thumbs up dude!Please don't just give out answers. Hints, suggestions, leading questions are great, but just giving answers seldom helps the TS learn anything other than how to get other people to do their work for them.
You and I are just not wired that way, others not so much. Maybe we should give a Trigger Warning that questioners should double check all answers since there may be purveyors of disinformation on the site.I didn't look closely at the offered answer since I really don't care whether such answers are correct or not, neither does the student a service (though, admittedly, I've been sorely tempted to give out right-looking wrong answers on occasion, too).
Thank you very much for your time and help.X=AB(!C)D+AB(!C)(!D)+(!A)BCD+(!A)BC(!D)=AB(!C)(D+!D)+(!A)BC(D+!D)=AB(!C)(1)+(!A)BC(1)=
7I believe that the man who opened a textbook on the subject, should understand everything. If he does not understand, then you should not help him. Besides, I studied in the USSR and in my mind there may be other words for defining concepts.
No. It doesn't work that way. Once something is posted, unless if violates the ToS, it stays posted (most of the time, even if it violates the ToS, it stays posted but the thread gets locked).can you please delete me from this forum?
Why? Because you were hoping that we would just work your homework for you and you discovered that we discourage that?Starting from your first reply I decided to longer be here
It would actually seem like we have more reason to appreciate his efforts than you do, you just don't realize that (yet)., i appreciate the time of the other member,
You didn't do me any wrong in any way -- you are doing yourself wrong, but that is a choice you get to make.thanks and sorry if i did wrong to you in any way,
In other words, you are concerned that your instructor will come across this thread and discover that you are just fishing for other people to do your work, that you won't put forth any effort to even start work on your homework problem, see that the wrong answer you turned in was provided by someone else, and realize that you couldn't even be bothered to check it.please remove my threads and too my account ASAP.
