suitable car charger for Samsung android phone
Discussion in 'General Electronics Chat' started by lse123, Jul 24, 2012.
  1. lse123
    Thread Starter Active Member
    Oct 17, 2006
    87
    I bought a Samsung general car charger (in:10-30V, output:5V, 700mA) for my Samsung Note Android 2.3.6 device(this phone has wall charger: in:240V, output wall outlet:5V, 1.0A)... well is ok to use (as of Volts/Amperes)???
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    maybe..maybe not. 700 is less than 1000mA
    Probably ok..
  3. lse123
    Oct 17, 2006
    87
    since is less, there is no possibility destroy phone, is it?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You should be ok with a 5v 700mA charger.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    If the 700 ma charger fails, it will fail by not charging the phone, not by overpowering it.
  6. lse123
    Oct 17, 2006
    87
    I have found another Nokia general car charger (in:10-30V, output:5V, 500mA) is it suitable for my old phone:
    Asus M930 device win 6 std device (this phone has wall charger: in:240V, output wall outlet:5V, 0.9A, but Asus battery says output 3.7V)
    http://www.gsmarena.com/asus_m930-2322.php
    also for this is suitable (thread #1 above) the Samsung general car charger (in:10-30V, output:5V, 700mA) ?
    adapters the same===usb micro, all...
  7. evilclem
    Member
    Dec 20, 2011
    118
    16
    Should be fine. The phone only expects 500mA at best from a USB port anyway.
  8. lse123
    Oct 17, 2006
    87
    So both car chargers work fine with both phones... correct? Yes correct / No
