Suggestions required for small embedded computer
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Jun 23, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I need a camera interface which some audio output. Image taken has to be processed inside & its contents to be spoken out.
    Earlier I thought of using raspberry pi as it has camera & audio out, then internally OpenCV can be used.
    But it has large form factor, I need something smaller. Also raspberry pi has large footprint & major problem is its current consumption also.
    I need to tailor down my application for this task only.
    2. Any suggestions on it which board can be used?
  2. mcgyvr
    Oct 15, 2009
    4,787
    974
    How large is too large?
    How much current consumption do you require?
    You need to define what size/current draw is acceptable to you..
    Required processing speeds,etc..
    You have very little useful information in your post.
    Its going to take power/current to process images.. plain and simple..
    Seems some have opencv working on arduino nano boards but I'd guess a computer is also part of that..
