Suggestions for microprocessor
Discussion in 'Embedded Systems and Microcontrollers' started by saharsahar, Aug 19, 2010.
Thread Status:
Not open for further replies.
  1. saharsahar
    Aug 16, 2010
    28
    hi all, can anybody help me to find a microcontroller with onboard ADC to support ultrasonic ,
    thanks so much
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    How do you intend to use "ultrasonic" with and ADC? A lot more detail would help in spec'ing an appropriate uC.
    Ken
  3. retched
    Dec 5, 2009
    5,201
    313
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. saharsahar
    Aug 16, 2010
    28
    the ultrasound frequency maximum range is 150 KHz which suports ultrasound bat calls.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The upper limit of echolocation calls may be less than the 150 KHz figure. Sampling theory suggests that the conversion needs to be done at least twice as fast as the upper frequency of interest, and even then the reproduction can be iffy. Requirements for memory to hold the data can be a challenge as well.
    At any rate, there are three threads open on the same subject. It would be less confusing to close all but the original - http://forum.allaboutcircuits.com/showthread.php?p=269562#post269562
Thread Status:
