thanks for the link, shortbus
Hi Alec:Welcome to AAC!
1) Assuming the common terminal of the twin-filament light is presently grounded, can you isolate it from ground? This would enable an easily-obtainable N-channel MOSFET to be used for switching both filaments.
2) Are you prepared to accept a reduced life for the light? Filaments don't take kindly to being repeatedly switched on and off.
3) Be aware that flash rates of about 7Hz can trigger epileptic seizures in susceptible people.
Thanks for the reference. I wonder where webbikeworld got this info. Gonna go fish about in the DOT guide... if I can find one on line. In any case, then I just need to figure out what sort of device I can rig up that will follow these regulations... even with these parameters it still seems like I oughta be able to DImyself as opposed to plunking $70+The flash rate and intensity for a modulator in the US as listed here are:
- The rate of modulation shall be 240 ±40 cycles per minute.
- The headlamp shall be operated at maximum power for 50 to 70 percent of each cycle.
- The lowest intensity at any test point shall be not less than 17 percent of the maximum intensity measured at the same point.
That may be an official "requirement" but no one is going to examine your circuit to make sure it does not switch the ground, if you are building it only for your own use.Having regard to posts 14 and 19, it looks like controlling the ground connection is a non-starter .
Yes, sorry. You're right JoeJester... I missed that reading small text on my phone with old eyes.They got it from the US Code as they referenced it on their webpage.
Hi Br-549. I am curious as to what you meant here? thanksIsn’t that something. I quit reading after the switch.
I think I’m pro VW now.
Well... maybe. This is anecdotal but I think it is also a good template for what happens when it all "works." I lived in LA when I was a little kid... the air was brown and I was sick with asthma at least half the year. We moved to Northern California and suddenly little Steve was pretty good at sports. I came back to LA to go to UCLA when the air was still brown, and was sick half the year again. There were smog alerts a few times a year and I remember (literally) being unable to climb the hill from campus to dorm because I was sucking wind like a 90 year old emphysema patient. I transferred to UCBerkeley, and suddenly, I was hiking, running, playing soccer and baseball. Hell, I even joined the boxing club. In 1992 I moved back to LA and you know what? The brown air had turned blue. It's even better today. It has been many years since there was a smog alert... and several at least since there has been any kind of smog warning at all on the west side of town (near UCLA) where I live. This amazing transformation didn't happen because industry (auto in particular) volunteered to change things. The market didn't force it to happen. There are some regs that are ludicrous, for sure. There are all sorts of victimless crimes that shouldn't be crimes, for example. But it was clear that short-sighted corps were poisoning us because it helped their bottomlines, and the pushback against them that has directly resulted in citizens suffering less is, imho, kind of a good use of our gov't.Howdy Steve,
That was my feeble attempt at sarcasm. I couldn’t believe those regs on modulating a headlight.
I can just imagine trying to cope with regs involving a combustion process.
It’s no wonder that company's like VW, and individuals cheat on regulations.
Or hire lawyers to argue definitions when caught and fined.
It’s such a parasitic waste.
The waste would be having no regulations, as Steve noted.....................
The complication is that the ground terminal of the sealed beam unit is common to both filaments. The existing wiring switches 12V (6V?) selectively to the non-grounded terminals, so a rewire would be needed to 'turn the unit upside down' (electrically, not physically).what would be wrong with a (perhaps simpler?) ground-interrupt modulator for the high beam line only
Don't see why that's a problem.The complication is that the ground terminal of the sealed beam unit is common to both filaments. The existing wiring switches 12V (6V?) selectively to the non-grounded terminals, so a rewire would be needed to 'turn the unit upside down' (electrically, not physically).
Do you feel safer now? That's the excuse for this intrusion.
10th Amendment is ignored.
True. Brain not in gear .Don't see why that's a problem.
If you interrupt the ground, only the high beam will be modulated if only the high beam is on.
by Aaron Carman
by Aaron Carman
by Aaron Carman
