I'm trying to keep this as simple and small as possible since it will be mounted on a motorcycle.
The circuit is a PWM fan speed controller, it will monitor the analog gauge sensor voltage already on the bike but I could replace that with a simple NTC thermistor.
This IC does everything I want it to do including having a fault indicator output which, although not 100% essential, would be nice to have.
The bike has a regular 12V lead-acid battery with the usual charging system that can jump as high as 14V. The fan is rated 12V nominal, no more than 3A at full speed.
Where I'm at:
A TC642B driving a logic level FET
http://ww1.microchip.com/downloads/en/DeviceDoc/21756b.pdf
(Ignore the way they designed in the SENSE part, I'll get that pulse in a different manner thus eliminating the resistor.)
What I'm wondering:
Is there a similar chip produced that will run with 12-16V for the supply instead of me having to give it a separate +5V? The few extra components are really not that big of a deal, just wondering if anyone had seen anything similar. I'm also somewhat limited in that I'd like to stay away from surface mount components.
Where I'm at:
What I'm wondering:
