Suggestion regarding RF amplifier
Discussion in 'General Electronics Chat' started by jamee, May 6, 2014.
  1. jamee
    May 6, 2014
    Hi friends,
    Urgently need some advice in purchasing off the shelf RF amplifier for my application. I have to amplify a 25 MHz,( ~0.5 to 1Vpp) sinusoidal signal to ~12 Vpp in my experiment. This is needed to drive a electro-optic phase modulator operating at 25 MHz.
    I have no background in electrical engineering, and do not quite know what would be the right kind of RF amplifiers for my application?
    I thought I could use the Minicircuit's ZFL-500LN low noise amplifier. It is rated for ~24 dB gain. But then I found that max input it can amplify is only 50 mV pp. Beyond that the output was saturating. The max undistorted signal that I got from ZFL-500LN is about 1.5Vpp. This is a roughly factor of 10 less than what I was hoping for. I would greatly appreciate if you could suggest some alternative. Many thanks in advance.
    I look forward to your reply.
    Cheers,
    James
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    There's nothing wrong with padding down the input to bring the drive signal to less than 50mV. In fact, this often helps to make things more stable. You won't need all that gain, but it doesn't hurt to not use it all. :)
    Eric
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
