Suggestion for choosing a D/A converter for 3Vpp 3500Hz sine wave?
Discussion in 'The Projects Forum' started by Choongho Chung, Sep 4, 2014.
  1. Choongho Chung
    Sep 4, 2014
    I'm trying to purchase a D/A converter for generating an analog sine wave
    ->~3Vpp voltage
    ->linear sweep from 200-3500Hz and constant(programmed by matlab)
    ->supply ref voltage for amplifier circuit(Not intended to supply driving power)
    I have absolutely no idea which company or which product I should
    start from to implement my specification.(I've never used A/D or
    D/A converter, nor have I used and digital I/Os so far...)
    Which company and which product should I look for?
    Any suggestions or examples would be extremely helpful.
  2. crutschow
    Mar 14, 2008
    13,472
    3,361
    What accuracy/resolution do you need?
    How may digital samples will be used to generate each sine-wave cycle (in other words how smooth does the sine-wave need to be)?
  3. Choongho Chung
    Sep 4, 2014
    8bits or higher should do the job..!
  4. MrChips
    Oct 2, 2009
    12,623
    3,451
    You can try Analog Devices AD558. It is 8-bit DAC, parallel interface, voltage output, 5V single supply and easy to use.
  5. crutschow
    Mar 14, 2008
    13,472
    3,361
    You didn't answer my second question.
  6. MrChips
    Oct 2, 2009
    12,623
    3,451
    I could answer that question but best to let the OP think about it himself.
