Suggest Me Any Simple Circiut ...
Discussion in 'The Projects Forum' started by Public, Dec 26, 2006.
  1. Public
    Dec 26, 2006
    Hey there,
    I have to "Implement in Hardware" any simple electronic circuit, with following conditions:
    1- Contain only discrete components (no ICs) and maximum of 3 transistors.
    2- Wish to have brief information and component list.
    3- Please I need the simplest circuit ever, with minimum number of components.
    Thank you
  2. Distort10n
    Dec 25, 2006
    429
    Well, the simplest circuit would use 1 BJT transistor as a switch to turn on an LED.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I have a simpler circuit. Put a resistor across a battery to warm your hands and convert the chemical energy in the battery into heat. Replace batteries as required. Dispose of the dead batteries an an environmentally friendly way.
    You should be able to use Ohm's law to calculate the current. The heat generated can be computed from the power dissipated in the resistor.
    Twinkle-twinkle little star
    Power's equal I squared R
    NB. There is no violation of the 2nd Law of thermodynamics here.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Another option would be making Papabravo's idea with a light-bulb instead of resistors. By placing a shaped reflector behind the bulb, the circuit could be used to find one's way about in darkness. :)
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Truly, you have a dizzying intellect. I yield good sir!
