suggest me a name !
Discussion in 'Embedded Systems and Microcontrollers' started by extremeads1, Aug 26, 2007.
  1. extremeads1
    Thread Starter Active Member
    Feb 10, 2007
    64
    i 'm doing a project based on microcontroller in which i 'm going to monitor the parameters like water level, traffic density and provide accordingly visual warnings on display in the respective areas by the roadside as overhead display, as well as transmit these readings to a control room wirelessly so that these parameters can be monitored on computer.
    this is related to city's different parameter monitoring .
    any additional parameters can be implemented in this project or any other features can be implemented......................... plss suggest!
    what name should i assign to this project ,i'm not able to find a perfect name do you have any suggestions for assigning the NAME OF THIS PROJECT ?do reply.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I would call it I'm in my final year of University and I'm clueless.
  3. recca02
    Apr 2, 2007
    1,211
    i havent worked with microcontrollers so cant suggest a proper name .
    how 'bout study of microcontrollers and its application in (insert name here)parameter monitoring system?
    i m no good with these either.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    The project is about 'condition monitoring' so would suggest that you get that particular phrase in there.
    Dave
  5. Distort10n
    Dec 25, 2006
    429
    Since you are monitoring road conditions, and then send it to a large overhead display screen why not call it Asfault because you know people will create more accidents when trying to read it.
    Or you could call it Transview or something like that.
  6. techroomt
    May 19, 2004
    198
    -- watchdog ---
