Successive approximation help!
Discussion in 'Homework Help' started by simon.cathy, Dec 18, 2006.
  1. simon.cathy
    Dec 18, 2006
    I am constructing binary words from a given voltage, using successive approximation. What happens when the voltage is the SAME as a bit value(ie not greater, or less than).Hope that makes sense! Thanks.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    I would think that the comparators in most successive approximation A/Ds have hysteresis (Google), which precludes an indeterminate logic output level at the expense of a small amount of error. If no hysteresis is present, the succeeding latch (or flip-flop) can possibly go into a metastable state (Google).
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you get the spec sheet for one, the manufacturer usually does a good job of explaining the theory behind the A to D's operation. Analog Devices makes a zillion of them.
  4. simon.cathy
    Dec 18, 2006
    A quick look at Analog Devices tutorials shows a `greater than or equal to` sign, which solves my problem! Thanks for the pointer.
    Simon
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Having the two inputs of a comparator the same is pretty difficult to achieve in practice still one must account for the possibility. Ron H has hit the nail on the head with the assessment of the comparator being in terms of a hysteresis characteristic. The comparator has two thresholds VTL and VTH which define the low and high input voltages respectively required to trigger a switch at the output. In fact in the context of ADCs a comparator without this hysteresis characteristic is pretty useless. Consider the situation with high-frequnecy noise (say from interference) imposed on the low-frequency signal you are comparing to some datum signal. If there were no hysteresis characteristic (i.e. VTL = VTH), then at the the theshold point the output of the comparator would fluctuate wildly in line with the high-frequency noise as it fluctuated around the threshold point, thus making the output reading null. In this sense the comparator is performing a high-frequnecy filtering function.
    Dave
