Successive Approximation ADC binary output
Discussion in 'General Electronics Chat' started by x1222, Jan 18, 2012.
  1. x1222
    Oct 22, 2011
    31
    I built Successive approximation ADC. As I crank up the voltage, the ADC output starts counting up binary. What is the binary output suppose to tell me? Is there anyway to convert that into readable voltage value?
  2. joeyd999
    Jun 6, 2011
    2,759
    2,944
    You built an S/A ADC from scratch? Or you build a circuit using an off-the-shelf ADC?
    Can't help you in the first case: only you would know the answer.
    In the second case, usually you define a Vref, where the maximum number of digital counts out occurs when Vin=Vref. Then for any Vin<Vref, counts = Vin/Vref * 2^n where n is the number of bits.
    So, for, say an 8 bit ADC with a Vref of 2.56V, there will be 256 possible output values (0 to 255), each count representing a 10mV increase in Vin.
    x1222 likes this.
