Subwoofer Failure
Discussion in 'General Electronics Chat' started by messi_tnt, Apr 9, 2013.
  1. messi_tnt
    Jul 22, 2011
    12
    Hi everyone,
    My 2.1 speaker system has stopped working, the subwoofer does not start but the L/R speakers are fine when tested separately.
    So I opened the subwoofer and first tested its transformer which is 230V, 50Hz to (12V X 2), 1.2A and I can read about 100 ohms on the primary and about 15 ohms on both secondaries. And there is about 220V AC on the input but with almost 0.1V on both outputs when turned on.
    I noticed this white thing on one of the connections on the input and I do not know what is this??
    I doubt it is the problem, anyone has any idea??
    Regards
  2. Metalmann
    Dec 8, 2012
    700
    223
    Looks like a crimped on wire connector.
    You may have to cut the wires to check for continuity.
    Then get a new connector.
    messi_tnt likes this.
  3. messi_tnt
    Jul 22, 2011
    12
    Thank you very much for the quick reply. I will test it and let you know the result.
    Regards
  4. messi_tnt
    Jul 22, 2011
    12
    Just tested it and it was not the problem. I found the loose wire on board in another place and there is 12V AC supplied to the circuit now. But still it does not work, I will continue checking...
    Regards
