subwoofer crosover
Discussion in 'General Electronics Chat' started by electronis whiz, Apr 13, 2013.
  1. electronis whiz
    Jul 29, 2010
    519
    27
    I made a subwoofer a about a year ago old woofer no amp, so I added an amp from some old PC speakers I had. I put a filtercap in sires with it thinking that would let only the bass through. because it would charge up then release driving the woofer at bass frequency. talking to friend other day said inductor not capacitor, but not sure what to do for inducter, I have some really small tube ones and some from SMPS for filtering AC, but not sure those would work, or wether need biger like a small transformer or make one.
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    You have to wind an air core inductor. You can wrap it onto a toilet paper roll.
  3. crutschow
    Mar 14, 2008
    13,473
    3,361
    You can also buy such crossover inductors such as one of these.
    Here's
    a calculator that will help you determine the inductor size you need.
  4. tubeguy
    Nov 3, 2012
    1,157
    197
  5. crutschow
    Mar 14, 2008
    13,473
    3,361
    Tubeguy's suggestion is the best if the amp is only powering the sub-woofer since it avoids inductors.
    It also has the advantage that you can adjust the corner frequency of the filter with a pot.
  6. #12
    Nov 30, 2010
    16,663
    7,310
    The reason for air core in the power section is that it is impossible for an air core to saturate.
    If you're going to filter at low power levels, iron core (anything that is not air) is OK.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    #12 likes this.
