Acceptable!!! lol... this doesn't have any meaning. You either accept something beacause it is proved or you do not accept it because the opposite is proved. No middle situations here.We agree that I can say -1 + -1 = 0 is acceptable, because the "extremely rigourous" proof that meets your standards provided by mavromap makes the assumption 1 + (-1) = 0. So this one isn't an issue is it
It's more than an "assumption". That 1 + (-1) = 0" happens to be one of the axioms of the real number system so there really isn't anything that I need to prove here. However anything else you say needs proof (which I don't see). That -1 + -1 is equal to 0 or not needs a proof. The whole point of these conversation is to actually prove that (-1)(-1) = 1 so the arguments you use should either be axioms or proven propositions.
I don't have a problem with that. This is correct axiomatically.As for (-1)*(0) = 0
The whole problem with your approach is that you try to prove: (-1)(-1) = 1 using other statements which may be obvious but in fact need proof as much as (-1)(-1) = 1 does. If they are obvious why need proof? Well (-1)(-1) = 1 is as obvious as (-1) + (-1) != 0 !!!. You say (-1) + (-1) != 0 is obvious and you use it without proof.. but you don't accept that (-1)(-1) = 1 which is as obvious and you try to prove it!!! Inconsistent..
I don't know about the wheel but you can surely reinvent analysis if you want. Freedom lies in mathematics afterall... However any proof of even very basic statements like (-1)(-1) = 1 must be carried out rigourously (even in your analysis).. otherwise anyone can say anything..engineers don't reinvent the wheel
No argument with that..thank goodness the job of making the real world work is left to the engineers
Here is some helpful material on the subject: http://www.calvin.edu/~rpruim/courses/m361/F03/overheads/real-axioms-print-pp4.pdf
..even an engineer who can't reinvent the wheel (very simple) can understant it. For any questions feel free to ask...
