wrong.........that to easy,you have not been to the mountains for a long stay.
Absolutely right that visible light cannot penetrate solid objects. Interestingly, shorter waves (x-rays, gamma rays and cosmic rays) and longer waves (cell phone signals, TV, am radio, ...) can. Don't down play the longer waves, microwaves can cook you to perfection.You won't be blinded since light can't go trough solid objects.Unless you are staring at the sun like an idiot.Only danger is radiation which can cause cancer.Radio based equipment wont work and power grids would get overloaded and would shut down.Home appliances will most likely be unharmed.
Yes but earth's atmosphere blocks them, in case they managed to go trough and if it was a huge solar flare then this planet would been dead like Mars and we wouldn't be worried about not having electricity since nobody on this planet would be alive to use it.Absolutely right that visible light cannot penetrate solid objects. Interestingly, shorter waves (x-rays, gamma rays and cosmic rays) and longer waves (cell phone signals, TV, am radio, ...) can. Don't down play the longer waves, microwaves can cook you to perfection.
If that occurs, the carnivores will have a feeding frenzy ... as man's dominance of the planet will END.If over 99% of the population will be blind, maybe badly burned as well, then probably electricity will not be of major concern. Best not to worry about it.
Yeah good sir, but humans are persistent and adaptive species. the few thousands that will survive would try to rebuilt our civilization from scratch. so if electricity is indeed rendered useless shouldnt we have some technological alternatives or even better develop some countermeasures as a precaution for such a flash?If that occurs, the carnivores will have a feeding frenzy ... as man's dominance of the planet will END.
